Previous Topic: Schedule a PolicyNext Topic: Cancel a Scheduled Configuration
Customize Configuration Settings
You can customize configuration settings to your specific requirements and combine them with default configurations. Use the Customize and Preview Settings dialog to view or modify the effective configuration settings for a computer.
To personalize the configuration settings
  1. In the Schedule Policies dialog, click Customize and Preview.
    The Effective Settings dialog appears.
  2. Expand the left pane tree view to select a parameter section.
  3. Select the setting you want to personalize in the list view to the right, and click Customize.
    The Setting Properties dialog opens.
  4. Modify the value and click OK.
    The new value is shown in the value column in the list view.
    Note: To reset the value to the original value, click Use Effective.
  5. Click OK in the Effective Settings dialog to confirm the modification.
    The Setting Properties dialog closes and the new value is saved in the database. In addition, a Personalized Settings icon is added under Scheduled Policies.
