Software Delivery › Tasks › Deploy Software Package › Finish
Finish
In this final step you have to confirm your selection and schedule the deployment.
- Decide if the software packages should be distributed and registered at the domains by marking the corresponding check box.
- Schedule the deployment.
- Enter a job container name.
- Decide if you want to open the advanced job settings dialog when the Finish button is pressed.
