Select the options for a CD installation:
Check this box to allow for a CD-ROM installation
Specify the following two fields:
Provide a label for the CD.
In case the CD stores many programs, provide the path to the MSI file you want to register in the form Sub1\Sub2.
If you check this box, the package is not stored in the software library.
