The properties of a distributed procedure are:
Name of the procedure
Name of the domain to which the procedure was distributed
Location of the domain (if present in the Location field of the domain) to which the procedure was distributed.
Date and time when the procedure was distributed to the domain. If the procedure was distributed to the domain together with its associated software item (being an embedded procedure), the field states "Original Delivery".
The task the procedure is to perform. Task can be one of "Install", "Configure", "Uninstall" or "Activate".
The last three can only be performed on machines on which the procedure has already been installed.
