Provide the following information to make a copy of the fetched item:
Use the Browse button to select the proper path to the directory where you want the copy of the fetched item to be placed.
Check this box if you are using the DSM Explorer on another computer than the manager itself and if you want to give the path to a local drive on the manager.
Otherwise, do not check the box.
