Detailed information about the software procedure.
Identifies the script, executable, or command file that triggers the task (such as SETUP.EXE or INSTALL.CMD).
For more information, see Procedure Task
Identifies the type of file.
For more information, see Procedure Types
Additional values that are used as input to a procedure when that procedure is executed. These parameters are entered and used as any command-line parameters. Use a space to separate the parameters.
For more information, see Procedure Parameters
