Detailed information about the software procedure.
Indicates the startup file name.
For an embedded program, the subpath points to the directory where the procedure program file is located, relative to the selected software source volume. If the procedure program file is in the root directory of the selected volume, the path consists of a backslash (\). If the procedure program file is located in a volume directory, the path is, for example, subdir1 or subdir1\subdir2.
Lets you select the volume of the library item source from which the procedure to be registered originates.
Specifies the type of file.
For more information, see Procedure Types.
Additional values that are used as input to a procedure when that procedure is executed. These parameters are entered and used as any command-line parameters. Use a space to separate the parameters.
For more information, see Procedure Parameters
