Previous Topic: Volume PropertyNext Topic: Volume File Dialog
Create Volume
Name
Name of the source volume.
Source Path
Enter the path or use Browse button to select it
Source is on Manager
Check this box, if you are using the CA ITCM Explorer on another computer than the domain manager itself and you want to give the path to a local drive on the domain manager (as seen by the manager). Otherwise, do not check the box. If this box is checked, the Browse button is grayed out.
Note: If you use this option, you cannot use UNC paths: You have to manually map a drive at the manager to the actual location and use that path instead. For example, if the UNC path is \\Server\share\dir, map x: to \\Server\share and then use the path x:\dir instead of the UNC path.
