General information about the software procedure.
Identifies the procedure.
Identifies the type of action being performed by the procedure. Valid options include: INSTALL, UNINSTALL, ACTIVATE, and CONFIGURE.
Identifies the operating system under which the procedure functions. The available operating system platforms are listed in the drop-down selection box.
Specifies when the procedure was registered; "Original delivery" if the procedure is embedded.
Otherwise the date and time when the procedure was added will be displayed.
Specifies who filed the procedure, for example Local Administrator.
Provides additional information about the procedure. The comment appears in the Comment column of procedures lists displayed on the screen.
Note: You can also use the comment as a default custom administrator message for the jobs by selecting the Use comment as user message check box.
(If checked) Ensures that this procedure comes first in the procedure drop-down list when setting up a job.
(If checked) Specifies that the procedure is included in the Software Catalog and enabled for user selection.
(If checked) Specifies that this procedure is not executed as part of the Re-install after crash (RAC) process.
(If checked) Specifies that the information entered in the Comment field is used as a default custom administrator message for the jobs when the procedure (or the package including this procedure) is deployed while creating the deployment job. The comment is automatically added to the User Message field available on the Job tab. You can always modify this information in the User Message field, if required.
