Based on completion time, the job history can be automatically cleaned up. This reduces the number of objects in the database and speeds up the performance of searching the database. Note that neither Installation Jobs, if they refer to a software that is still installed, nor Delivery Jobs, if the software is still present in the Staging Library, are cleaned up.
Job history cleanup time: nnn days n hours Start at: nn : nn
The jobs cleanup task is run periodically using the cleanup interval above; the job history cleanup is run every day at the specified start time.
