Use this tab to define the operating systems (platforms) on which the module will run. You can specify the corresponding executable for each enabled operating system (platform) in the text field next to the check box.
Note: Do not change any specifications in this tab for the existing modules unless you have specific requirements.
The following table provides a list of operating system specific executables that are available for the modules:
Platform |
Executable |
Windows 32 bit |
Win32 Generic |
xxxxW32.EXE |
OS Specific |
Windows XP |
xxxxWNT.EXE |
Windows CE |
xxxxWCE.EXE |
MAC OS |
xxxxMAC |
UNIX/Linux |
xxxxUX |
In the Executable, xxxx is the module ID for the chosen module.
Note: The executable specified must be available on the agent computer in one of the following paths:
- <install path>\bin directory for (Windows) or
- <install path>/Agent/AM/plugin directory for (UNIX/Linux)
