Define Time Ranges for ACEs
Use the Time Ranges tab page to define time ranges for all Access Control Entries (ACEs).
To define time ranges for an ACE
Time ranges for ACEs are enabled.
A single entry refers to a 30-minute period, whereas a time range entry with two values is as specified. For example, entering a value of 7:00 indicates a 7:00 to 7:30 time period, whereas entering 7:00 - 9:00 indicates a 7:00 to 9:00 time period.
Time entries currently have a granularity of 30 minutes; you can only specify a time entry with "00" or "30" as the minute component. So, for example, a time range of 8:00 - 11:30 is valid, but 8:10 - 11:15 is not. (See the examples at the end of this procedure.)
Default: Normal Weekdays
This value can be any combination from Sunday to Saturday, for example, Sunday Tuesday or Monday - Friday. (See the examples at the end of this procedure.)
For each of these fields, the number 0 (zero) represents a wild-card match, so 0/7/4 (Y/M/D) would match the 4th of July for all years. (See the examples at the end of this procedure.)
The time range is added to the Time Ranges table.
Examples
Hours |
Type |
Weekday |
Year |
Month |
Day |
Description |
8:00 - 18:00 |
Normal Weekdays |
Monday - Friday |
Monday to Friday 8:00 to 18:00 |
9:00 10:00 |
Special Dates |
2008 |
12 |
26 |
December 26, 2008 9:00 to 9:30 and 10:00 to 10:30 |
