Previous Topic: How to Use the ENC Authorization Rules Configuration ViewNext Topic: Map Security Objects to a Realm
Define a Realm
Use the Realms tab page to define the realms in use within your ENC infrastructure.
To add a realm to the Realms table
  1. Enter the name of the realm in the Name field and click Add.
    The realm is added to the Realms table.
  2. (Optional) Select a realm in the Realms table and click Remove to remove it from the list.
  3. (Optional) Add any relevant notes about the use or contents of the specified realm in the Note field.
  4. (Optional) Click Local to set this realm's configuration policies to Locally Managed.
  5. (Optional) Click Default to reset the realm's configuration policies to the original default values.
  6. Click Check to perform immediate validation of the data entered without committing the data.
  7. If cross-field or cross-table validation is successful, click Apply.
  8. Click the Name Mapping tab.
