Previous Topic: Select Detection Modules for Hardware Inventory Collect TaskNext Topic: Software Discovery Collect Task
Create Legacy Agent Collect Tasks
For Unicenter Asset Management 3.2 extended and legacy agents, you need to create inventory tasks for automated detection and collection of data that include the new inventory modules you just created.
To create a collect task for hardware inventory
  1. Right-click Control Panel, Configuration, Collect Tasks in the DSM Explorer tree and then click New.
    The Select New Collect Task Type dialog appears.
  2. Click Hardware Inventory and then OK.
    The Select New Collect Task Type dialog closes and the Schedule New Collect Task dialog appears.
  3. Replace <enter name> with the name for the new task, for example, Legacy 3.2 General Inventory Task.
  4. Click the Detection Modules tab, and select the inventory modules you want to add to this inventory task, like Legacy 3.2 Detailed Unix Software Inventory and Legacy 3.2 General Inventory, for example.
  5. Click OK.
    The new inventory task is added to the Hardware Inventory pane.
  6. Assign this inventory task to either a legacy group or a legacy agent.
