Querying is a crucial advantage of using a database. You can query the database to search for assets that meet the specified criteria. You can use a query to maintain membership of dynamic groups. The members of the dynamic group change according to the results of the query. You can also create a policy based on a query and apply the policy on the resulting objects. Asset management also provides predefined queries that perform basic and advanced querying of the database. You can use the Query Designer tool to create complex queries easily.
Note: For more information on queries, see the DSM Explorer Help.
