Previous Topic: New OS Image WizardNext Topic: Add Item
Register Boot Image Wizard
This wizard guides you through the process of registering a boot image.
It contains all necessary information to complete the task. If you need more details, please consult the OS Installation Administration Guide.
The basic steps to register a boot image are as follows:
  1. Select the image to register
    Note: When CA ITCM is in FIPS-only mode, the images that are not FIPS-compliant display the type "Not FIPS-Compliant". You cannot use these images to set up OS installations. These images have a BDSM--r12.5 FIPS_UnqualifiedIcon--ICOicon to indicate that the images can no longer be used.
  2. Select how to register the image in a domain
  3. Specify the domain and the domain credentials
  4. Review the settings and start the image registration
More information:
Images Flagged as Not FIPS-Compliant
