The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Views Node › How to Use Configuration Views › How to Use the Common Configuration Configuration View › Configure the CSM/CCNF Manager
Use the CSM/CCNF Manager tab page to configure the common configuration manager and the CSM manager.
To configure the CSM and CCNF managers
- Click Job control.
The Job Control dialog appears.
- Specify the values for the following policies:
- Configuration message retry interval
- Configuration message delayed retry interval
- Configuration message timeout
- Replication message retry interval
- Initial replication delay
- Click Save.
You are returned to the Common Configuration dialog.
- Click Task scheduling.
The Task Scheduling dialog appears.
- Configuration job check interval
- Group and computer update check interval
- Linked domains check interval
- Time span for processing configurations
- Time span for processing incoming messages
- Time span for up full configuration report requests
- Click Save.
- Click Database.
The Database dialog appears.
- Database request timeout
- Task check delay
- Use client side cursor
- Click Save.
- Click OK.
Your manager settings are saved and applied to the configuration policy.
