Asset Management › Collect Tasks › Software Usage Collect Task › Create Software Usage Collect Tasks
You can create a software usage collect task to track the usage of software licenses based on the settings given in the software definitions.
To create software usage collect tasks
- Navigate to the appropriate Collect Tasks folder.
- Right-click the folder, and select New from the context menu.
The Select new Collect Task type dialog appears.
- Select the Software Usage option, and click OK.
The Schedule new Collect Task dialog appears
- Specify appropriate information in the following tabs, for details click the link:
- General
- Applications
- Online
- Auditing
- Advanced
- Click OK.
