Asset Management › Collect Tasks › Template Inventory Collect Task › Create Template Inventory Collect Tasks
You can create and configure template inventory collect task to collect information related to the selected user template.
To create template inventory collect tasks
- Navigate to the appropriate Collect Tasks folder.
- Right-click the folder, and select New from the context menu.
The Select new Collect Task type dialog appears.
- Select the Template Inventory option, and click OK.
The Schedule new Collect Task dialog appears.
- Specify appropriate information in the following tabs:
- Click OK.
