The OS Installation wizard starts with a welcome message explaining its task and result.
The wizard guides you through the steps required to setup a new OS installation for the selected computers.
The result of the wizard is an Activated OS installation which will be initiated when a target computer is rebooted next time.
Alternatively you can edit boot parameters before the activation of the OS installation and activate it yourself manually.
