The OS Installation Management tab displays Information about OS Installation Management
If this checkbox is checked, the computer is enabled for OS Installation Management. If not, you can check it, to enable the computer for OS Installation Management.
Note: You may disable the computer from OS Installation Management with "Delete from OS Installation Management".
The name of the computer will be displayed. If not, you have to enter a valid computer name here.
The DNS name of the host will be displayed. If not, you have to enter a valid host name here.
The MAC address of the computer will be displayed. If not, you have to enter a valid MAC address here.
Displays the name of the OS image currently installed with OS Installation Management.
Click the option "Assigned automatically" (recommended) or select the name of a boot server from the drop-down list.
