Previous Topic: FDCC Inventory ModulesNext Topic: SCAP Configuration Dialog: Advanced Tab
SCAP Configuration Dialog: General Tab
The SCAP Configuration dialog lets you view or configure the checklist information that you want the inventory detection module to scan.
Note: You can either use this dialog to configure the checklists or enter the parameters manually in the text field provided in the Configuration tab. For more information about the parameter names and their descriptions, see the appendix SCAP Configuration Parameters in the Asset Management Administration Guide.
The General tab includes the following checklist-related details:
XCCDF Id
Displays the unique ID of the checklist as specified in the XCCDF file. This field is read-only. It gets populated automatically when the engine creates a new FDCC inventory module.
XCCDF Version
Specifies the version of the checklist. If you have more than one version of the checklist in the ITCM_Installpath\SCAP_Checklists folder, the drop-down lists all the available versions. Selecting the Use Highest option, uses the highest version always. The scanner performs a string compare of different versions of a checklist to get the highest version. For example, if there are two versions of a checklist v1.1 and 1.2, the scanner will treat v1.1 as the highest version.
XCCDF Profile
Defines the title of the XCCDF profile to be applied for the compliance check. A profile is a section in the XCCDF file that defines various variables and settings in the file. An XCCDF file may contain one or more profiles. Selecting Default from the drop-down list lets the scanner use the first available profile in the XCCDF file. Selecting None applies no profile, which means the default settings are used for all the values and rules in the XCCDF file.
Collect XCCDF Result File
Configures the collection of the XCCDF result file for the checklist. Select this option to let the scanner securely copy the XCCDF result file from the Asset Management agent's working directory to the domain manager after every checklist scan.
Collect OVAL Results Files
Configures the collection of OVAL result files for the checklist. Select this option to let the scanner securely copy the OVAL test result files from the Asset Management agent's working directory to the domain manager after every checklist scan.
