For each boot image, the following is shown:
Specifies the name of the image.
Specifies the type of the image.
A boot image is either of type DOS or WinPE.
If the image has not yet been registered, it is labelled as "detected" only.
Specifies the long name of the operating system. For example, Windows PE 2.0.
Lists the image flags defined for the image. For more information about Image Flags, see the OS Installation Management Administration Guide.
Note: This field is empty for images that are created with the earlier version of CA ITCM.
Specifies the date and time of registration of the image; subsequently, if the image is modified, this field is updated to include the date and time when the image is modified.
Comment that appears in the SD product.
Default: BsmBtImg imagename
