The General section lets you specify the policy name, policy severity, and the query for the policy.
This section contains the following fields:
Defines the name of the policy.
Indicates the severity of a policy.
Default: Message
Indicates that the policy needs more attention and has a severe impact when violated. An Alarm Policy appears in the Alarm section of the Log Overview.
Indicates that the policy is typical for advanced notification or for a potential problem. A Warning Policy appears in the Warning section of the Log Overview.
Indicates that the policy is for informational purposes only. A Message Policy appears in the Message section of the Log Overview.
Records the event whenever it is triggered. You can view the policy history in the History folder of the respective policy in the DSM Explorer.
Keeps the history for the specified number of days. On the last day, it starts removing the records from first day. For example, if you keep the history for 5 days, at the beginning of day 6, the day 1 records are removed.
