Depending on the type of job, whether the target system connects directly to the domain manager or via scalability server and what download method the target system is configured to use, a number of states will be used to visualize the progress of the computer job.
There are three general types of jobs:
Execution job is the common name for installation, activation, configuration and un-installation jobs.
For execution jobs the following states are used:
This and the following states are only used if the job requires a DTS file transfer either to a Scalability Server or to the target system.
o
SW Delivery Halted
o
SW Delivering
If no DTS transfer is required this will be the first visible state for the computer job and it means that the software package is available to the agent at the Scalability Server it connects to.
The Manager has sent the job to the Scalability Server and is waiting for confirmation.
The Scalability Server has received the job and confirmed it.
The job is being executed by the agent.
The job was executed successfully by the agent.
The job has failed for the reason specified in the Status Message.
Used for installation jobs only and indicates that the software already is installed on the target system
Used for any type of job and indicates that the job is conflicting with another active job e.g. an attempt to run a configuration job is done while the software in question is being uninstalled.
For library delivery jobs the following states are used:
SW Already Delivered
For library removal jobs the following states are used:
SW Removing OK
SW Removing Error
