The Select MIF Item dialog displays the contents of the selected MIF file in a tree view structure. You can drag any of these items to the fields in Create New External Asset Class Definition dialog.
Note: On Linux, the MIF files must have the extension .MIF (case-sensitive).
This dialog contains the following field:
Displays the MIF file that is currently open. Click the ellipses (...) to select a different file.
