You can create multiple instances of engines on the same computer. On the domain manager computer, the main engine is called SystemEngine; while on a remotely installed system, it is called computername_Engine. You can right-click any such engine and create its new instance. The new instance will reside on the same computer.
Having additional engine instances is useful in the cases where:
To create a new instance of the engine
The Create new Engine instance dialog opens.
The newly created engine appears under the All Engines folder.
Note: The new instance runs on the same computer as the selected engine. To distribute engines on the other computers, you need to install a new engine on the chosen computer using the CA ITCM installer.
