The DSM Explorer › Control Panel › Deployment › Continuous Discovery › How to Use Continuous Discovery › Configure the Agent (Continuous Discovery)
Use the Continuous Discovery Policy: Agent Configuration wizard page to specify additional configuration details for the payload when it is delivered to the target.
To configure the agent
- Enter the IP address or fully qualified domain name (FQDN) of the scalability server with which the agent will register and connect.
- (Optional) Specify additional Windows, UNIX, Linux, or Apple Mac OS X install options as appropriate using the "Please enter any additional...install options" field.
Note: For more information about Windows and UNIX install options (also called properties) and their values, see the sections on installation using the command line in the Implementation Guide.
- (Optional) Click Advanced Options to specify additional parameters to be passed to the primer installation.
- Click Next to go to the Summary page.
