Previous Topic: Select Field DialogNext Topic: Define Directory Search Dialog
Search Possible Values Dialog
The Search Possible Values dialog displays all the possible values for the selected field in the Select Field dialog.
This dialog has the following fields:
Value filter
Specifies the filter condition. You can select the operator in this field and specify the criteria in the adjacent field. You can perform a wildcard search on the text fields and use the relational operators on numeric fields.
Result Limit
Defines the number of records shown in the Value List list box.
Default: 100
Value List
Lists the possible values after applying the filter condition and result limit for the selected field in the Select Field dialog. You can double-click any item to add it to the drop-down on the Select Field dialog.
