Previous Topic: System Delivery EngineNext Topic: Engine Tasks
SystemEngine
The SystemEngine pane shows the scheduled tasks due to run on the domain manager's main engine.
The Tasks pane has the following options:
Start/Stop Engine
Toggles the activation of the engine.
Activate Engine
Forces the engine to start the next scheduled tasks immediately.
Add New Task
Opens the New Task Wizard where you can create a new task.
Link Existing Task
Opens the Select Engine Task dialog where you can choose a task to deploy to the engine.
Note: For detailed information about engine trace settings and the engine logs, such as TRC_SystemEngine_#.log, see the Implementation Guide.
