Previous Topic: Add Directory Argument DialogNext Topic: All Queries
Select Query Dialog
The Select Query dialog lists the existing queries that you can link and add as an argument to another query.
Note: You can link only the queries targeted against the Computers and User Accounts objects.
This dialog contains the following fields:
Query List
Lists the name of the existing queries targeted against the Computers and User Accounts objects and their respective targets.
Link Method
Specifies the method used for linking the queries. You can configure the link method with the following options only when you are linking the computer queries with user account queries; in all other cases, the Query Designer uses the default link method.
default
Matches all the registered relations between the users and the computer.
Owner by usage
Matches the registered relations based on the number of times a given user has been registered as a user of the computer, and returns the most used computer.
Most recent user
Matches the registered relations depending on when the relation was registered and returns the most recently used computer.
