The Software Delivery tab displays fields that control the software delivery specific aspects of a computer or a user profile:
Displays the current status of an asset. Valid values are: Operational / Locked by RAC / Locked by Move / Locked by Roam / Locked by Migration / Locked by RAC & Move / Locked by RAC & Roam.
Specifies the download method for the currently supported operating environment. Valid values are as follows:
Windows: Makes use of MS Network for agent access to files on the domain manager.
UNIX: Makes use of a UNIX server that uses Samba shares.
Makes use of SD internal protocols for download to NOS-less agents from their associated domain manager.
Makes use of DTS for download to NOS-less agents from their associated domain manager.
Specifies the name of the CCS calendar associated with a job.
The Reinstall After Crash (RAC) policy specifies how the software delivery domain manager handles notification that a new operating system has been installed. Valid values are as follows:
The common policy will be used for this computer.
A RAC job container will be created and activated, starting the delivery of job orders to the computer.
A RAC job container will be created. It can be reviewed and modified, since it has to be activated manually.
RAC is disabled on this computer. No job container is set up for this computer. However, its installation records in the installations folder on the manager will be marked as removed.
This box should be checked if the computer is a software managed system (that means, it is only using software installed by CA ITCM, and this software was registered into the software package library using CA's Software Management Packager.).
If you try to install software not created and registered by that Packager on such a computer, the job will fail with an error code stating that the "Procedure is not allowed to run on the target system because it is marked as Software Managed".
