The Agent tab contains agent-related information.
This tab contains the following fields:
Identifies the agent name.
Identifies the date and time when the agent was registered.
Identifies the date and time when the agent was last run.
Identifies the last IP address of the agent. If the agent is configured through DHCP (Dynamic Host Configuration Protocol), each time the DHCP Server is restarted, a new IP address is assigned to all the systems connected to the server. This field displays the last IP address of the agent.
Identifies the host name of the scalability server that this agent reports to.
Shows the agent restrictions, if any. Valid restrictions are as follows:
Identifies the various agent plug-ins that support this user account.
Provides a brief computer description.
