Reposition Procedures
The procedures that are part of a Procedure Dependencies folder can be ordered.
The procedures that are part of a Procedure Group folder can likewise be ordered.
A context menu opens with the choices:
Moves the procedure one step up
Moves the procedure one step down
Moves the procedure to the top of the list
Moves the procedure to the bottom of the list
Deletes the procedure
The procedure will be moved one step up in the list
The procedure will be moved one step down in the list
The procedure will be moved to the top of the list
The procedure will be moved to the bottom of the list
