The Application section lets you add the application to be monitored.
This section contains the following fields:
Lets you select the software usage event you want to track.
Lists all the applications (software definitions) available in the domain for which the software usage monitoring is allowed. Select the application you want to monitor.
Note: If you have enabled history tracking, you can see the history of changes in the History folder of the respective policy.
