Previous Topic: Select Collect Tasks DialogNext Topic: Disable a Collect Task
Unlink a Collect Task from an Asset
You can unlink a collect task that you no longer want to execute on an asset or an asset group.
To unlink a collect task, right-click the collect task and select Unlink from the context menu.
Note: Unlinking a collect task from the asset does not delete the collect task from the domain.
