The Organize Product dialog lets you add the following:
This dialog contains the following fields:
Defines the name of the software definition to be searched.
Defines the version of the software definition to be searched.
Specifies the manufacturer for the software definition.
Specifies the software definition type to be searched.
Specifies whether the definitions must be a member or non-member of the selected category.
Filters only those software definitions that are discovered by the asset management agent.
Searches the selected software definition type for the given values.
Displays the title and version label of the resulting software definitions. You can select the items you want to add to the product, release, or suite.
Note: To select multiple items all at once, press the Shift key (continuous selection) or Ctrl key (random selection) and click the items.
Adds the selected items to the Selected Definitions section.
Note: Clicking this button does not add the items to the product, release, or suite.
Adds all the items in the Search Results section to the Selected Definitions section.
Displays the title and version label of all the added definitions. These definitions are added to the category when you click OK.
Removes the selected items from the Selected Definitions section.
Removes all the items from the Selected Definitions section.
