Use the Approved Licenses tab to specify the number of approved or purchased licenses for the specified release, suite, or virtual application image definition.
This tab contains the following field:
Defines the number of approved licenses for the release, suite, or virtual application image. You can view the difference between the number of installations and the approved licenses in the Discovered folder of a group. At the domain level, you can view the applications that have more installation than the approved licenses.
