Use the Registry tab to specify the parameters for matching the windows registry information.
Note: Use this parameter for the Windows operating systems only.
This tab contains the following fields:
Specifies the registry key that needs to be searched.
Example: HKEY_CURRENT_USER.
Defines the path in the selected registry key that need to be searched.
Example: Software\Microsoft\Internet Explorer\Version
Defines the value that needs to be matched with the registry key or value.
Example: 5.\3*
Note: If you do not specify any value in this field, the asset management agent searches the specified path and returns true if it finds either an existing key or an existing value.
