Use the General tab to specify the general information about the definitions such as the name and version.
This tab contains the following fields:
Defines a unique name for the definition
Defines the version of the definition.
Example: V1.0.
Defines the query version of the definition.
Example: 1.0.0.0
Specifies the manufacturer of the definition. If the manufacturer you are looking for is not in the list, you can create a manufacturer in the Manufacturer folder.
Describes the product.
