The DSM Explorer › Troubleshooting
Troubleshooting
This section contains the following topics:
Failed to Set Server Address of Computer
Symptom:
When I try to change the scalability server of an agent, one the following error messages is displayed:
- Failed to set server address of computer.
- The Server Address of an Agent cannot be changed on a Scalability Server.
Solution:
Do the following:
- Ensure that the agent and server are currently online.
- Verify the credentials that you provided for the agent are correct.
- Verify if the agent is on the same computer which also hosts a scalability server.
Note: You cannot change the scalability server of an agent, when the agent is on the same computer as the scalability server.
