You can view a report on the software selected in the Discovered Software pane. This report includes information about the software name, asset name on which the software is installed, installation path, number of installations, and so on. If you select multiple software, this report displays the details for all of them.
To view a software report for the discovered software
The Discovered Software pane displays all of the software detected for the selected computer.
The Software Report for Computer dialog appears.
Displays the name of the application (regular or virtual) or virtual application image.
Displays the type of software discovered. Valid types for all software definitions include Release, Patch, Product, Suite, and Virtual Application Image.
Note: If the discovered software is virtualized, then the software type may be further refined as Staged Virtual Release, Staged Virtual Application Image, Standalone Virtual Patch, and so on.
Displays the name of the asset that has installed the selected software. When you generate this report at the group level, it can display the name of member assets that have installed the software and the total number of installations in the group.
Displays the installation path of the software on the asset.
Displays the number of installations of the software on the asset or asset group.
Note: If you want to export the report to CSV format, click the Export button, and specify the file name and location in the Enter output file dialog to save it in your hard drive.
