Target Related Macros
Selects the computer name and LAN id of the PC, the Item Procedure is executed in.
Expanded value:
ComputerName ComputerLanId.
Supplies a string of fixed drive letters. Expanded value: CDE (string of drive letters).
$hd is not supported for UNIX item procedures.
In this macro you can, within the brackets, refer to a parameter, which is stored in the Software Delivery database on the Software Delivery server, if the following actions have been taken:
1. a parameter package has been created, using the Packager, and registered in the Library
2. the parameter package has been installed on the Software Delivery server, which is to evaluate the reference to the parameter.
The contents between the brackets has the structure X/Y/parameter, where X=the packaging computer where the parameter package was created and Y=the parameter package.
$() can also be used in queries and as user parameter when defining jobs.
