The Software tab displays the applications discovered on the current computer. The extent of information shown in this overview depends on the collect module you have specified under Configuration, Collect Tasks.
Note: Available categories and options may vary depending on the products and components installed.
Important! The asset management agent searches the entire hard disk for the given executable file. Even if the file is in the recycle bin on the computer asset, it is discovered as an installed application. Make sure to completely remove the executable files from the hard disk when you are uninstalling the product.
