Configure External Applications Dialog
Use this dialog to specify the external applications that can be started from the selected unit. For example, the computer unit can have these external applications linked, Ping Computer, Trace Route, Event Viewer, or Internet Explorer.
Lists the applications currently selected ordered by name, file name, and parameters.
Opens the Add application dialog used to add additional applications to the list.
Deletes a selected application from the list. The application is removed immediately. You are not prompted for confirmation.
Opens the Properties window of the selected application.
