Previous Topic: Scalability Servers FolderNext Topic: Group Properties Dialog (Scalability Server)
All Scalability Servers Folder
The All Scalability Servers folder includes all the scalability servers in the network that are registered with the domain manager.
The scalability server folder has the following context menu options:
Explore From
Opens a new window allowing you to view all the scalability servers in this group.
Paste
Stages a sealed software package on all scalability servers. You can choose whether to stage the package with default or custom settings.
Empty Progressive Tree
Removes all nodes in the tree view that have been added by double-clicking or pressing the Enter key on nodes in virtual lists. This option is available only when there are nodes in the tree.
Software Jobs
Opens the Stage Software Package Wizard. For more information, see the Software Delivery Help.
Permissions
Opens the Object Permissions dialog.
Properties
Opens the Group Properties dialog where you can view group-specific information about the current group of scalability servers.
