The Jobs folder gives you a list of all Jobs defined for an asset.
Jobs direct agents or engines to perform specific actions. You can execute various types of jobs on agents and define as many jobs as are required in each job type. After you create a job, you need to link it to a specific unit or group of units on which you want to execute the job.
The Jobs folder is used to create new jobs, view all the jobs available in the domain, view the units executing each job, and view the job status.
Note: The Jobs folder is available in three places in the root of the left pane, under each asset, and under each group.
Note: Available categories and options may vary depending on the products and components installed.
These job categories appear as subfolders under the Jobs folder. Each of these categories has different type of jobs that can be performed. These job types appear as subfolders under the respective categories.
The organization of the jobs folder lets you view the jobs with respect to each job category and job type. The All Asset Jobs folder under the job categories displays all the jobs under the category.
