The Jobs folder lists all jobs defined for the selected asset.
The Tasks section in the right-hand pane contains the following links:
Opens the New Job Wizard which allows you to create a new job.
Opens the Select Asset Jobs dialog, which lets you select the modules you want to add and deploy to this asset.
