Previous Topic: Categories FolderNext Topic: softwaredefinition
All Definitions
The All Definitions folder contains all the software definitions known to this domain.
The All Definitions pane shows more detailed information about the individual software definitions such as name, type, description, manufacturer, and version information.
Double-click any definition item in the list to expand it in the tree view.
Right-click a software definition under All Categories to open its context menu:
Enable Scan
Enables heuristic or signature scanning.
Disable Scan
Disables heuristic or signature scanning.
Explore From
Opens the selected software definition in a separate folder.
Copy
Copies the selected software definition to the clipboard and lets you paste it in a different folder.
New Release
Opens the Create new Release dialog.
New Suite
Opens the Create new Suite dialog.
Organize Product
Opens the Organize Product dialog.
Delete
Deletes the selected software definition. Also deletes all discovered software records for this definition.
Permissions
Opens the Object Permissions dialog.
Properties
Opens the Properties dialog for this software definition.
