This option is only applicable if you have selected either Set up jobs or Set up and activate jobs.
If checked, this box ensures that you will not enter a loop where jobs are automatically generated, go into error, are regenerated, go into error, and so on. Instead the faulty jobs can be inspected and renewed.
In other words, new jobs for exception members will not be set up, if a failed job exists from a previous activation ordered by the evaluation, under condition that the previous job container is available for renewal.
If the previous job container has been deleted manually, reevaluation of the template will set up jobs as appropriate.
